    Snes joypad with Gamecon-controllers question
    GamePad/GPIO/USB encoder
    snes gpio snes
    • ogroto
      ogroto last edited by ogroto
      Hello everyone, hope you are doing fine and sorry if this is not the correct section to ask. I'm in the middle of a snes pi project and the joypads come next. I have found this guide and have a question to anyone that did this https://github.com/recalbox/recalbox-os/wiki/Gamecon-controllers-(EN)
      The pinout for snes is:
      alt text
      So my question is, according to the guide, GPIOXX the data pin, which i will go with GPIO04 for player 1 and GPIO07 for player 2, the rest of them should go soldered together to both ports of player 1 and 2? that's 5v, ground (these 2 ones 100% sure) and latch, clock ? I have a RPi 3 model B. Thanks in advance for your time.
        I read the doc the same way as you : data is the only independant pin
        ogroto 1 Reply Last reply Reply Quote 0
        • ogroto
          ogroto @Substring last edited by ogroto
          @subs said in Snes joypad with Gamecon-controllers question:
          Thank you subs, i am pretty confident now,that this should be the way to go. Got player 1 working and will try the 2nd now!
          Got it! it was that way, only data is independent pin 😄
          • elf0
            elf0 last edited by
            ![alt text](0_1474685666273_upload-a2054753-5416-4d87-a033-4d745d2d0e2c image url)
            is corrrect?
              I don't remember the data pins on pi2, but i answered a topic like a week ago abt that. Remember that the data pins you choose have to be mapped at the driver level in the recalbox.conf
              100.2k
